MHS CM-5 Problem
profile.country.bg_BG.title
Emilii
MHS CM-5 Problem
Hi i have bloggie CM-5 and some times when i open it the light witch indicates that the camera is ON lit's. But the display doesn't and the camera is not working. Then I must take out the battery to restart it. The camera is in warranty. Should I take it to Sony???
Tags (4)
StartTheCar
Hi Emilli
Always difficult to be 100% sure if there is a fault without actually seeing the product.  However it clearly doesn’t sound right or reflect my experience with this model.  With this in mind, and if possible, I would always recommend taking back into the supplying retailer, who can obviously check it and take the appropriate action.
Best regards
Lee
Emilii
10x for the fast reply mate.I will probably do that :wink:
