diaphragm/ shutterspeed dsc h200v
profile.country.nl_NL.title
naboo1
Hallo. I recently bought a cybershot dsc 200v camera. I read the manual en tried different things in the ´menu´ but can´t find how I can change the diaphragm and shutterspeed? What am I doing wrong? Nanda
Mick2011
Hi naboo :slight_smile:
You need to set the dial on the top of the camera to A, S, or M. This will let you set the Aperture and Shutter, or you can use manual mode.
Have a look at these explanations and get back to us if you have any further problems:
http://esupport.sony.com/docs/dvimag/DSCHX200_HX200V_guide/en/contents/02/03/06/06.html
http://esupport.sony.com/docs/dvimag/DSCHX200_HX200V_guide/en/contents/02/03/05/05.html
http://esupport.sony.com/docs/dvimag/DSCHX200_HX200V_guide/en/contents/02/03/07/07.html
Mick
Mick2011
Mick
