HS20v compared to HS20BB
Jephsha
Just about to buy an HS20V when I noticed what looks like the indentical camera on sale in PC World and Currys called the HS20BB. Anyone know the spec differences?
blaireau_photo
Hello Jephsha - Welcome to the Sony Forums :slight_smile:
The letters after the camera name usually denote the intended market region of the product. Therefore, it is highly likely that the spec is exactly the same - it is just the product code that is different.
For further information, the full specs are listed on the main Sony website here:
HX20V
http://www.sony.co.uk/product/dsc-h-series/dsc-hx20v/technical-specifications#tab
Thanks,
Simon
blaireau_photo
HX20V
Thanks,
Simon
Jephsha
Thanks for the info. Seems odd though that Curry and PC World are selling a HSC20BB wheras all the rest are selling an HX20V. However as the V version is the cheapest via Amazon will go down that route. Jephsha
GoNz0-
It is part of the pcworld/currys list price / price matching scam.
they insist major suppliers like Sony, Panasonic etc change the model number of the product by 1 digit or 2, this allows them to offer price matching ( and over inflated list prices) against a product, the problem is the model is unique to them so price matching isn't available and they cannot be fined for inflating the list price.
I noticed this with my Panasonic TV a couple of years ago.
This also allows them to prey on the stupid who really think it's a bargain as the list price they set is now £399 against £249 in the real world.
£249 being Sony online, says it all really.
reasons not to use PC world.
