Hx400v flash sync and my metz 45ct-5 flash
bill040158
I have my metz 45ct-5 flash from my wedding photo kit.  Can I se this on the hx400v?  If so what is the flash sync speed?
When I used it for weddings on my Hasselblads I didn't have to worry as the camera would sync at any shutter speed.
Looking forward to your comments.
EdwinaU
Moderator
Hi Bill,
Thanks for joining the community.
There is some guidance for using an external flash in the manual for your camera here but you would need to do a further check into the compatibility of the Metz. I found a similar discussion here, it's not for the same camera but might offer some useful information.
Best wishes,
EdwinaU
bill040158
Thanks for the advice and the links.  I'm just a little worried about the voltage at the end of the sync cord
might fry my camera's circuits.  Also I would have to use it with a hotshoe adapter as there isn't a flash
socket on the camera itself.
If anyone knows anything about this, I would be greatful for the advice.
Regards,
Bill.
