HX7V i-manual as a PDF?
gazz1e
Does anyone have a PDF version of the HX7V i-manual? It's the manual available at http://esupport.sony.com/docs/dvimag/DSCHX7-HX7V_guide/eng/index.html. I don't always have an Internet connection on holiday and I'd like to keep a copy of the manual for reference on my tablet.
Many thanks,
Gary.
Tags (2)
Mick2011
No-one is suggesting you should buy Acrobat, simply that Acrobat is the tool needed to make PDFs from HTML pages. A lot of large businesses use it so you can often email the link to a friend who may have access to it.
I've since had a trawl around and found you an online .pdf version: http://www.docs.sony.com/release/DSC-HX7_HX7V_guide_EN.pdf
Mick
Mick2011
Hi Gary :slight_smile:
You just need something like Adobe Acrobat Pro to render the HTML-based i-manual as a proper, hyperlinked PDF.
If you have that or know someone who does, it's a fairly simple, automated process.
Mick
gazz1e
Thanks for the advice, but I don't fancy paying for Arcobat Pro $200 just to have a manual that I can access offline. The camera didn't cost much more than $200. I imagine it'll be more cost effective to buy another camera.
Mick2011
Mick
