problem code 43
dafrank76
problem code 43
My EReader PRS-600 has stopped being recognised by my laptop and is showing problem code 43. I have tried it with another computer with the same result. It has worked OK for about a year and has only just started causing a problem is there anything I can do?
5 REPLIES 5
carpetmojo
I don't know the 600, but presumably it has a re-set facility, hard or soft ?
Someone out there might know what a 43 is.
U sual practice is try a soft reset if it has this.
Hard reset's usually mean you lose everything on the device.
You have run a-v ?
carpetmojo
dafrank - don't know if this helps, but this is the M/soft description of the code :
http://technet.microsoft.com/en-us/l...8WS.10%29.aspx
Hope it helps - definitely outside my limited tech-knowledge I'm afraid.
carpetmojo
Sorry - forgot.
Read this (lengthy! )  thread, too.
PRS-600 won't sync or transfer files from computer to Reader. Can anyone help please, Manual is usel...
It is in lower left panel on your thread page...
dafrank76
Hi thanks for the link I'll give it a try.
maxileona
mein ebook reader prs-t2 zeigt den Fehlercode 43 an, was kann ich tun
