Connection
Connection
Hi will the Sony xb10 connect with the srs12
Hi there,
Hopefully a community member will be able to help.
Best wishes,
M
Joe_Dohn
Specialist
Both speakers only support Speaker Add, which means that you can only connect an identical speaker to it (2 XB10s or 2 XB12s) but won't connect to other speakers.
