DVD recorder
Gordon36
DVD recorder
I have a GXD360 DVD Recorder used just for transferring DVC camcorder tapes to DVD.  Recently on applying power the message "WELCOME" appears, as normal, but doesn't go beyond that however long I wait.  Disconnecting, then reapplying power does not change the situation.  Is there a likely cause for this?  More to the point, can anyone suggest a solution?  Many thanks.
Pascale_F
Moderator
Hi Gordon,
Welcome to the Community.
You could contact
Sony Support about this.
Thanks,
Pascale
