HDR RESOLUTION
Kontiki1977
HDR RESOLUTION
HELLO, rooobb,
ref my STRDH790AVR it does  support D/V with alll do respect but whatever i do the
resolution stays misty grey with loss of image quality Ive got 2 D/VISION 4k discs Apocalyspe now
and the shinning when DV set on bdp only it makes little diff older movie perhaps not cleaned up
by film co.setting picture mode HDR  to HDR10 helps a little but goes quite dark..
Sean_Mc
Moderator
Hi there,
I think you might have meant to post this reply to a previous thread. If you can respond to the original post for further assistance.
Best wishes,
Sean
Sean_Mc
Moderator
Hi there,
Best wishes,
Sean
