Nickname
miwilli65
Nickname
Just (re) joined Sony community. I think I had a nickname from about 10 years ago: How do I search for this and if possible change my newly allocated (and rather silly) nickname?
6 REPLIES 6
Sean_Mc
Moderator
Hi there,
So I can try to help, can you give me the ID to your profile and also the new username you want to use.
Best wishes,
Sean
miwilli65
Hi Sean
miwilli65 is the ID I was allocated.
I think I 'was' 'MikeW403' previously.
(I may be wrong, but if you can fix it so that becomes my 'new' ID, I'd be grateful.
Regards
Mike
miwilli65
Hi Sean I think I 'was' MikeW403.(I may be wrong, but if you can 'fix' it so that this is my 'new' ID, I'd be grateful)
Thanks Mike
Sean_Mc
Moderator
Hi again,
I've just sent you a PM regarding your request.
Best wishes,
Sean
miwilli65
Thanks Sean: My current ID is miwilli65.
Some variation on MikeW403 would be fine as my 'new' ID/Username.
.. Hope I've understood your question properly.
Regards
Mike Williams
miwilli65
Re: Nickname
Regards
Mike Williams
