Sony Vaio all in one
domlim
Hi Members,
Does anyone know where I can get hold of a replacement screen for a All in one computer Model VGC V3S.
And, has anyone come across the fault where there are numerous vertical lines. If so, was this due to screen faulty or graphics card/other hardware faulty besides the screen.
Thanks. Look forward to hearing from you guys.
Peter_S.
Genius
Hi domlin,
I don't think there is a new screen available for this PC as a spare part. With a little luck you might be able to find one on the relevant used goods portals.
Anyway, according to your description of the fault I would agree that the screen is defective.
Peter
