HTX8500
Doogocha1
HTX8500
Tech question:
Does anyone know if there is an internal fuse in the HtX8500?
My daughter plugged her electric bike charger into it by mistake, a 42v charger!
Easily done though as they look the same and are same size
HannahEd01
Community Team
Hey, usually the fuses are in the AC adapters, not sure if the system has an internal one. best thing to do is to contact Sony directly by chat-email- or even calling them to get this info.
P.S they might need to research it out because I'd only assume that's not an easy info to get. https://services.sony.co.uk/supportmvc/en/contact?pdp=ht-x8500&cat=home-theater-sound-bars-home-thea...
Doogocha1
Hi Hannah
Thank you very much
I'll check with Sony
