Stand by light flashing red
Hskerritt22
Hoping someone can shed light on this.
My daughter went to switch on her Sony Home Audio System MHC - V77DW and it won’t turn on. The stand by light just keeps flashing red and goes off.
Any ideas?? Thanks
Pascale_F
Moderator
Hi Hskerritt22,
Welcome to the community.
I'll look into this for you and see if I can find out. Someone else in the community may be able to advise in the meantime.
Thanks,
Pascale
Win_88
Specialist
Hi Hskerritt22,
The maximum she can do is try a power cycle (unplug from the mains for a few minutes then plug back in again).
If the issue remains, I'd recommend contacting her nearest service center: https://locator.sony/en_GB/servicecenters
Win_88
Hskerritt22
Thank you. We did try this and it did turn back on however the volume wouldn't work.
So I did it again and the volume came on!
No idea what that was all about but thank you for the advice.
