I Have just received from Amazon my BDV-N590 Home Cinema system, only to find it has a 2 pin plug.
a) Is it still OK for UK use?
b) Is it possible to rewire into a 3pin plug?
c) Are there adaptors, or someone recomend one?
Don't really want to mess around packing it all back up for a possible minor problem
Any advice?
this is a serious error on Amazon's part as they do not normally send out goods in the uk with the wrong plug connectors, it is however possible that the plug adaptor be in the box or its been removed previously, i would strongly suggest you contact Amazon about this as they should send out a replacement or at the very least the correct plug adaptor for it.
