Amazon Prime on BDP-S5200
far.regard
Hi - I recently performed a recommended update via the internet on my BDP-S5200. Immediately thereafter, any time I try to run Amazon Prime Video (which previously ran just fine), I get the spinning circle for about twenty seconds and then the entire unit turns off. How strange is that? I’ve tried this probably five times, always with the same result. Netflix and all the other streaming services work just fine. I’ve tried running a network and software update again, but it only ever says, “Already updated.” Help? Thank you!
4 REPLIES 4
Sean_Mc
Moderator
Hi there,
Have you tried to perform a Factory Reset on the unit?
Let me know how it goes?
Best wishes,
Sean Mc
far.regard
Sean,
Thanks very much for the suggestion. I’ve done a factory reset on both the system settings and network settings. No luck; same result when I try to open Amazon Prime...
Jeff
Sent from my iPhone
Sean_Mc
Moderator
Hi Jeff,
It might be best to get in touch with the support team here for further help with this.
Best wishes,
Sean Mc
far.regard
Thank you, Sean; will do.
Sent from my iPhone
