Compatability
provostkaypark
Compatability
I have a HT-ST5000 connected to an AF8 and a RHT-G950 connected to my new 43XG8396.  On both these set ups I am unable to display on the screens the info from the remotes of the soundbar and Theatre System.  Surely all being Sony products they should be able to talk to each other and dispaly necessary infoirmation.  Anyone with any suggestions etc?
Hi there,
Hopefully a community member will be able to help.
Best wishes,
M
9 REPLIES 9
Hi there,
Best wishes,
M
The_Black_Rose
Specialist
Hi provostkaypark,
I am a bit confused. By display the info do you mean the information banner doesn't appear or do you mean the menus?
Cheers,
The_Black_Rose
provostkaypark
Thanjks for your reply.  When I use the remote for the soundbar no information at all appears on my tv screen.  I have to go closer to the illuminated display at the front of the sound bar to see what I am trying to do.  I have today been informed by Sony that
please be advised that on the same page you respectfully shared with us (page 30) it is mentioned clearly in the notes on the bottom right hand side that the sound field menu does not appear on the TV screen for TV input. Therefore, the display option will not help you to get the sound field information on the TV screen.
I am not toosure what this means but I suppose I will have to live with it!!
Tenneen9000
Hi Provostkaypark,
Can you share that link here? Maybe we can help shed more light on the situation.
All the best,
Tenneen9000
FELIZADASA
@Tenneen9000 wrote:
Hi Provostkaypark,
Can you share that link here? Maybe we can help FileZilla UC BrowserRufusshed more light on the situation.
All the best,
Tenneen9000
provostkaypark
Hi there.
When you press the appropriate button on the remote control the only way to see whaqt is displayed is by going near to the unit and reading it - should it not appear on the tv screen making it easier to operate/choose settings etc?
The_Black_Rose
Specialist
Hi provostkaypark,
Is the connection via optical cable or HDMI?
Cheers,
The_Black_Rose
provostkaypark
Sent from Mail for Windows 10
HDMI
Atso
The_Black_Rose
Specialist
Hi provostkaypark,
Have you tried using a different HDMI cable?
Cheers,
The_Black_Rose
