BDP-CX960 No longer loads cover art from GraceNote database
mfnatik
Is there a fix for this issue? I've tried a factory reset and it did not resolve. Have also tried reloading all discs multiple times now but will cover art will not populate. Anything else I should try?
5 REPLIES 5
Hi there,
Have you updated to the latest firmware?
Best wishes,
M
mfnatik
Yes, of course. That was years ago though. There hasn't been any updates for a long while now.
EdwinaU
Moderator
Thanks for letting us know. We'll look into this and let you know what we find.
Best wishes,
Ed
batee5
Specialist
Hi mfnatik,
Welcome to our community!
I've checked on the BDP-CX960 but it doesn't seem to be a European model. I suggest seeking support from Sony in the country of origin. Also, I learned it's an old model (a 2009 model I think) so I don't think it's still supported by Gracenote.
Cheers,
Batee5
mfnatik
It's still able to access gracenote but the cover art doesn't display. Seems to be something has changed either with their format and or the firmware is now outdated? Can someone at Sony investigate? Seems to be an easy fix on Sony's part to keep long term owners of this excellent product happy.
