BDV-N590 Home Theater System speaker channel issue
ConnollyMan
Hi
Had this system for just under a year now after initially reading fantastic reviews. I had treated myself to a large 3d tv which my older Sony surround system didn't not support fully. It has been great until yesterday when I decided to use the  auto calibration function & it kept "failing". I found out it was because the right surround speaker was not working. It's not the speaker itself as I swapped the plugs at the unit & it was fine so appears to be the channel. Any one else had this problem and know a fix or is it off to a Sony repair centre?
MK_Slinky
I've not had the same problem but as you've ruled out a faulty speaker it pretty much suggests a dead output.
I certainly can't think of anything in the settings which would effect this.
Sounds like a repair job to me.
Bad luck! :slight_frown:
The User Manual is your friend..., seek forth and ye shall find answers. Can't find any? Join the club, we have all the answers here, occasionally they're even right! :wink: Dr.Slinky McVelvet - Inventor of the word 'Mellifluous' - 30.12.14
ConnollyMan
Thanks for you prompt reply.
Did suspect that might be the answer but thought I'd ask the question, even to find out if a common fault. Fortunately still within warranty.
Sent from my iPad
MK_Slinky
Phew...! That's a stroke of luck then, let's hope they get it fixed without too much delay.
All the best
