BDV-N590 low sound quality, sparks while plugging in power
profile.country.HR.title
the_shredder
I've just bought BDV-N590 and I noticed when I was plugging in power cord in outlet that there was a brief spark.
Then, I noticed that home cinema (the device itself) has been creating high frequency sound while on. It is not the fan, but something in device.
And at the end, I was disappointed in sound. The sound is clear, but it sound "metallic" and "empty". It is noticeable while watching a TV (connected with ARC), less while playing a movie with 5.1 sound, but more while playing music - especially from CD.
My questions:
1. Should device make hissing (high frequency sound while on)?
2. Is sound quality good, especially while playing a music from CD?
the_shredder
Since this topic is searchable by Google, it is only fair to give conclusion.
So, I contacted store but they referred me to Sony service. I brought device to Sony service but they couldn’t reproduce sparks. Nevertheless, they replaced power supply. The home cinema does not produce high frequency sound and the spark between power cord and outlet doesn’t appear anymore.
Thank you!
5 REPLIES 5
Catmambo
Hi
Sounds strange - have you checked out another demmo model in a store to see how that one sounds. Hard to say without hearing it personally, but might be worth brnchmarking it against another one. If it is faulty, you should be able to get it swapped out by the retailer if its within 14-30 days depending on the store..
thanks
the_shredder
Thank you for reply.
Unfortunately, the store doesn’t keep that particular product in display or even in store. They had to ordered it so I could buy one.
Catmambo
Hmm, its an end of life model so you might find it tricky to find another actually. Might be best to raise it with the store and see what they say as it shouldn't be emitting a high pitched noise..
thanks
the_shredder
Meanwhile, I’ve messaged one of local review sites. They confirmed that the device itself (although they tested BDV-N790W) makes high frequency sound while playing disc.
Also, I’ve connected device to my PC and I played a bit with equalizer on Winamp and Windows Media Player because my nVidia GeForce card does not offer equalizer on HDMI connection.
I’ve noticed that “poor sound quality” I’m experiencing is because of high frequencies. 12k, 14k and 16k are bursting through on Winamp when set to high values, also for Media Player on 8k and 16k.
I’ll contact store on Monday, thank you again for advice.
the_shredder
Thank you!
