i get no signal being received on tv. HDMI cable is working ok
Solved! Go to Solution.
question a little vague, so try this, on tv remote with both devices on change the input (looks like a screen with arrow in it) usually HDMI 1 until the DAV displays, then you should be able to set HDMI control on the DAV remote to on (find it in system settings under set up) once done you should be able to turn ON the DAV and the tv using the DAV remote.
