I quite like my now rather old HS20, and would prefer to not have to upgrade just yet. However, since an accidental clout on the top of the unit, the HDMI input seems goosed, as it will not display anyhting other than error messages when I try and feed it 720 or 1081(i) from my STB or PS3.
Component input works ok, ( via pjmulti ) as does s-video, but I would really like to use the HDMI connector, as swapping the PS3 diplay outputs is a PITA.
I expect a "service" or repair charge by a Sony dealer will be silly money...... any ideas anyone ?
Solved! Go to Solution.
Hi there
Does HS20 = VPL-HS20?
It sounds as like a hardware issue. In the projector, there are a couple of PCB Boards that contain the input/output connectors.
QA Board
Four types of signal formats are compatible with the input jacks on the QA board:
QB Board
The QB board contains three input jacks supporting both analog and digital video sources.
Now considering that Component and S-Video works, therefore this "appears" to be a problem with the QB board.
The QA and QB Boards are then fed to B and C Boards for processing.
Service Tips:
Thats all the relevant information that I have.
I will say though, that I am not a technician or engineer, this information is "As-is" and maybe totally incorrect.
Therefore I strongly recommend contacting an authorised Sony Repair Centre (as it is a hardware fault anyhow) : HERE
Hi there
QA Board
QB Board
Service Tips:
Thanks for that detailed and speedy reply - first of the year too 😉
I understand it pretty much - except that the component signal I am using goes via the multiplug connector which is using the QB board right?
No probs by the way.
Im a little unsure on the signal flow between the two. Sounds right I think,
A little bit more information for you:
Good luck with everything as well
EDIT: Next time dont throw the PS3 controler at your projector !!!!!!! <grin>
TY again, I may try and get an old unit for spares, and try swapping out the boards, starting with the QB I think.
PS: it was the cat LOL
Me again - I had an idea to try:smileythumbsup:
Using a temporary 3 mtr HDMI to DVI-D lead, I plugged a Bluray player in directly, selected DVI on the HS20 ( set to GBR video ) and got a very good picture. However, there is an issue it seems with the longer ( approx 10mtr ) installed HDMI lead that runs through ductwork, and across my loft to the HS20 input. Whenever I try it as above, using a convertor plug to swap from HDMI lead to DVI-D plug, I get nothing. I suspect the HDMI lead may be duff, possibly damaged during installation - but wonder whether its worth the hassle of installing a new one? If I can get this setup to work, it solves the troublesome issue of having to keep alternating the PS3 display settings between component ( which is what I currently use to feed the HS20 ) and HDMI ( for the tv display ) as the PS3 will only output any one type of signal at any one time.
I guess my main question is this.....
Is DVI-D better than component ?
Thanks IA
Hi there
With DVI-D to HDMI it keeps the entire signal digital. Component adds an analog conversion. Ive found a rather interesting thread that might be a good read for you:
http://www.ecoustics.com/electronics/forum/accessories/104899.html
Hope that helps.
Seems that will indeed be best to try and resurrect the HDMI cable and use the plug convertor to feed the PJ a nice clean digital signal then - which will allow me to use my AV amp HDMI inputs/output to switch as required from STB to PS3.
Thanks again for your helpful response 🙂
Your welcome. Good luck with everything.
