Moving from: sony dav dz340k To E3100 .. not kinda satisfied !!
profile.country.SA.title
Hamad366
Hi
i jus bought Sony 3100 home theater for another place .. I used to use sony dav dz340k Model for long time and I was happy with it .. but when I compare it to the new one I feel like the new one is kinda weaker! And the voice is not the same feel lik it's very sharp
-is it beacuse some settings that I need to do ?
- or beacuse the speakers itself
beacuase I find out that the watt power not the same in every speaker like the older one!
in the 340k every speaker has 167w  x 6 = 1000w
but here in the E3100 front and surround only have 125w each !
And the center and subwoofer 250w
125x4 250x2 = 1000w
its written like that in specification in the website
- is that mean I should lower the center and subwoofer voice more and increase the others ?
-also I'm connecting th theater to a samsung tv using HDMI ARC Port .. is it better or I should use optical ? If hdmi is better is the cable came with the theater itself enough when playing Remux movies which have great sound quality like atmos and dts-hd etc.
5 REPLIES 5
Hamad366
please help 😞
any small help would be appreciated!
EdwinaU
Moderator
Hi there,
You will find some information to help you set up your speakers in the manuals here
There is also some advice about using ARC here.
We hope this helps.
Best wishes,
Ed
Hamad366
Tried the manual it's helpful but not fully..
I just want an answer for this now
In sound effect option:
should i change anything to dts bro or Dolby logic to get this format when I play Remux movies which I do by connecting HDD Via the samsung tv .. or I should leave it in sound mode and the system will automatically play any audio version when it's available if it's supported ?
LightFoot
Specialist
Hi @Hamad366
I can see that this is a 2013 model so I assume that you bought it second hand. Are you sure that it is in good condition and working properly. I can also see that there was a new firmware update made available on 05/03/2019.
https://www.sony.co.uk/electronics/support/home-theater-blu-ray-home-theater-systems/bdv-e3100/downl...
Hamad366
Yeah I know it's kinda old model
but as I know these are the models still available from Sony since I want only small size speakers with 1000W
- And yes I'm sure it's new device never been used before I bought it from Sony official store.
- yesterday I updated the system to the newer version .. sound seems better after some editing in setting
I just want to know now if need to change anything in ( sound effect )
should i I leave it in sound mode ? Or change to DTS neo or Dolby
