s2ony str-dn1030. -samsung remote interference
oohaah73
hello all
i have a sony str-dn1030 av receiver .(i am a newbie to av receivers and the 1030 can be quite difficult)
the problem i am having is that when i press play on my samsung bluray dvd player it changes the input on my receiver.
it gets very annoying having to get up and press play manually on the dvd player or change the source by hand on the receiver.
does anybody know if any thing can be done with either remote control or maybe in the receiver setup menu.
any help would be greatly appreciated.
thanks in advance
:slight_smile:
Mr_Onion
It seems like the remote codes are interferring with each other. Can you change one of the units remote codes? Yoy will have to delve into the manual to find it out.
