SA-CT60BT further problems
Bob_Rich
Hi All
I have looked at an eralier thread and it looks like that one had been solved.  `i have tried the ideas in that thread but the unit is still dead.
 I fixed it once by changing a bulging capacitor  it has stopped again. This time will not switch on at all no LEDs no response from controller nothing. opened up and had another bulging capacitor changed this but no change.  Interestingly the  the capacitor I changed had no voltage, when checked with my DVM, being developed across it. It is as though it is stuck in standby.   two other capacitors had  around 29V and 3.5V across then but no other voltage can be found The power supply seems to be based on a   SSC620 chip and waveform around this seem OK when checked with my scope.It looks like it was stuck in either standby or overload mode.  when looking at the back of the unit with the cover off ther is a small circuit board stuck to the right hand side . It is fed by a small plug with a red and white lead  any idea what this is for.
would welcome some help on this  it seems a shame to scrap it
Bob
EdwinaU
Moderator
Hi there,
We'll look into this and update you when we can. Some of our members may also have some tips for you.
Best wishes,
Ed
Win_88
Specialist
Hi Bob,
I don't really have enough information to help you with the electronic component of the sub woofer, but you can contact your closest service centre using this link:
https://locator.sony/en_GB/servicecenters
Win_88
