3D Glasses for KDL-42W828B
ehasanov
Hi
I'm thinking to buy additional 3D glasses for KDL-42W828B.
Which type should I buy.
Edin
ehasanov
Thanks for quick reply
Hi
According to the manual : HERE - you will require the TDG-500P model of 3D glasses.  P is for Passive.
Can be purchased : HERE if required.
ehasanov
