3d glasses
balzanc
3d glasses
What happens to the 3 glasses if you charge them with a device which is not Sony??
Bravia55HX
you can use any USB charger, any laptop, any tower system with usb ports to charge your glasses with no problems.
Catmambo
Should be fine as they charge via USB, so you could charge via any device which has a compatible socket as far as I know.
Bravia55HX
