40U2000
40U2000
Can anyone help? I have 40" Bravia but unable to get a picture at all. The flashing red light is flashing a 4 sequence but I cannot find any details on line for this particular sequence, Thanks
Thanks very much for taking time to reply, I am sure that you are right, have purchased a new 4k Bravia it is amazing how they have come on as you no doubt will appreciate. Cheers
Hi there
As you may probably be aware, the 4 blinks (flashing lights) indicate a hardware failure.  According to the information that I have for the KDL-40U2000 - 4 blinks = Panel Error.
Considering the age of the TV, its more likely to be economical to purchase a new one than to get this repaired.
Hope this helps.
