40wd655
Zeki333
40wd655
 Moze li mi netko pomoci oko povezivanja tipkovnice sa tv.
Naime rijec je o logytech k400 plus tv
Rade samo odredjene funkcije tipa esc...strelice..ali ne i slova i ...
Pete_B
Hi there Zeki333. Unfortunately we do not provide online support in the Croatian language. If you write your message again in English, you'll be much more likely to find the help you need here.
Cheers,
Pete
