46HX853 Switching to a specific HDMI when turning on
win2kpro
Is it possible to have the TV switching automatically to a specific HDMI  port? As when I am switching the TV on at the moment it would always go to tv channel nr 9?
Where can I set it to switch to HDMI1, HDMI2? Is that possible?
Hi there
I dont think its possible to auto-switch to a HDMI source when turning the TV on.  However there is a way to get close.
  • If you have a compatible device that has Bravia Sync (or even compatible HDMI-CEC functions), you can turn on the device that is connected to the HDMI port, and if settings are correct on the TV, it will automatically turn the TV on.
or.
  • When the TV is on, turn ON the device connected to a HDMI port, and it should auto switch to that device.
Hope that helps
