46NX723 is this normal?
profile.country.fi_FI.title
scented
I made a video about my tv. From the beginning i have thought that is this tv broken. Watching tv there is really bad some kind of pixelation and now that pixelation in my video is really makes me think is this broken? This was not so cheap tv so...
baddesign
@scented the video you posted no longer exists.
Does the pixelation look like this? (Angelina Jolie as youve never seen her before ) :grin:
Ive read on internet this is known as solarization
Hi there
Yes, you are correct, the problem in the pictures you posted is called Solarisation.  Unfortunatley is a hardware fault, and would need to be repaired by an authorised Sony repaire centre.  Issue becomes whether your TV is under warranty.  If not, the TV just might be uneconomical to repair.
baddesign
Thanks for your replies Quinnicus.
Yes, Ive already researched it & wasted so much time. Ive already spoken to SONY via phone. However as its over the 12 months warranty period, I'm left with another faulty, useless, expensive piece of badly designed SONY product.
Expensive lesson learned... NEVER BUY SONY PRODUCTS!
