49X8505B 2160p RGB
cessivo35
49X8505B 2160p RGB
I just got a PS4 Pro and I’m unable to get 2160p RGB resolution with my TV.
I know that it's not HDR, but I still don’t understand why I only get YUV420 colour format.
I get a notification from the PS4 saying that my TV might support higher resolution, but I cannot find any settings on the TV to activate an enhanced mode or similar.
Has anyone been able to fix this or is a new firmware update required?
Thanks,
Hi there
According to this FAQ:
http://sony-eur-eu-en-web--eur.custhelp.com/app/answers/detail/a_id/112975
Your TV will support YCbCr 4:2:0 when using 2160p@50 hz (which I am assuming that is what your TV is set at).
Hi there
