Apps no longer run on Bravia KDL-48W605B
redballoon
Hi
Last night i was using both the YouTube app and Netflix through my KDL-48W605B, today, only a handful of apps are displaying, the YouTube and Netflix apps don't do anything at all (pressing the Netflix button on the remote produces a "Feature not available" message.
Only a handful of Apps are listed.
Refreshing the internet content results in a success message, though on the odd occasion I get the 1107 error message.
The television is contected to the internet - I've tried bith wi-fi and hardwired - with the television giving succesful connections. My internet connection is fine, as my laptop, phone and tablet connect ok.
I've switched off both the television and router a few times and lef them off for a few minutes but still with the same issue when they are both turned back on.
Is there something wrong at Sony's end?
Hi there
This sounds like an issue that occured last weekend:
https://community.sony.co.uk/t5/televisions/all-streaming-apps-missing-or-not-working/td-p/2135470
By the time you read this, can you confirm if its still not working?
Hi there
redballoon
Hi, thanks for your reply.
In the end, I carried out another reset to factory settings and all the apps appeared and were working again.
Thanks.
