BBC iPlayer problems - July 2014
Danielcoz
I know BBC iPlayer has had problems this weekend but does Sony know when the problem will be rectified for Sony smart TVs?
Tags (2)
17 REPLIES 17
Helmutk
Done. (several times). Still the same.
'Cannot load programme - This is a temporary problem. Please try again later.'
Hi there
I know you said about rebooting the TV - do you mean Factory Reset?  If not, try doing that?
Also, what version firmware are you running?  I understand there might have been an update just recently?
http://www.sony.co.uk/support/en/content/cnt-dwnl/prd-tvhc/bravia-kdlw-firmware-update-v2193/KDL-50W...
Helmutk
it is the latest firmware, have checked. Will try the factory reset tomorrow.
Helmutk
Factory reset has sorted it, thanks.
frmitch42
I realised ove the past few days that my Sony TV (KDL-40EX503) could no longer connect to Iplayer. I was getting "temporary failure to connect to the server.. Please try again". After a bit of research I discovered that this is a known issue and that a firmware update was issued in June to deal with this. http://www.sony.co.uk/support/en/content/cnt-hn/prd-tvhc/improve-the-BBC-iPlayer-performance. I had to download the firmware and install it from a USB stick since my TV refused to auto update to the new firmware via its own internet connection.
This cured the problem, I can now load Iplayer no problem, and play the content.
The downside is that the version of Iplayer it installed will not play HD content. I checked the FAQ's on the Iplayer app and it clearly states it will not play HD. I have a high speed internet connection, so that is not the issue here. Can someone at Sony please explain why I'm given a version of Iplayer that will not play HD when I paid a considerable sum of money for a Sony HD Smart TV, on which I intended to watch in HD ?
Hi there
Unfortunately I think your question would be better aimed at the BBC, as its the BBC the controls and develops the application - whereas Sony's responsibility it to ensure it displays.
The Link I have to contact BBC regarding iPlayer is below, but for some reason, it wont load for me at the moment.
https://iplayerhelp.external.bbc.co.uk/templates/bbciplayer/emailForms/emailPage
EDIT: Thought I'd just mention that the BBC has over 1,200 versions of its iPlayer (a rediculous amount !!)  :slight_smile:
frmitch42
Thank you Quinnicus for your reply. Actually just after I posted, I discovered another thread in one of the recommended links below ,( BBC iPlayer Issues 2014 (MASTER THREAD) )
which discusses the consequences of the firmware update, and I discovered I am not alone in finding problems choosing higher quality downloads, others have the same issue, but they came to the conclusion that lengthier programmes over 3 hours had this issue, but not shorter ones. I need to check this out in more detail, meanwhile thank you for the link to the BBC.
Your Welcome :slight_smile:
I remember that conversation now, in regards to the length of the BBC program, and it was never resolved.  Hard to know whos resposibility it is to be honest, its a BBC application, but could be a limitation of the TV as well, so....
Edit, there is a break-away thread now - if you can post in their - Ill forward it onto Sony Support.
http://community.sony.co.uk/t5/televisions/kdl-40cx523-amp-long-programmes-on-iplayer/m-p/1716831
