bdv-e190 - compatible 3d glasses
mister-h1
Does anyone have any idea what galsses I should use with the BDV-E190 3D player? The pictures will be shown on a Samsung HDTV.
Hi there
Its not about what Bluray player you have. Its what TV you have. You said you have a Samsung TV. This means you need 3D Glasses from Samsung.
My advice is to make sure that you definately have a 3D TV, and then search Amazon for "Samsung 3D Glasses"
Hope that helps.
Hi there
Hope that helps.
mister-h1
Thanks.... Looks like more expense coming up!
No probs. While your at it, make sure that your HDMI cable is 3D complient as well, HDMI 1.4.
I know all too well on the cost of things. I did a full install on a new system November 2011
Total Cost = £2429 (hope link works)
https://docs.google.com/file/d/0B0FRB6rQ2ePkQUtNX2hxR3BMUFE/edit?usp=sharing
My Philosophy is - Do it once, Do it right!
