Blocking Youtube
hjcarter
Blocking Youtube
Any idea how I block YouTube from my KDL-37EX403?
Is there a setting on TV or a URL I can put into the firewall on the router.....
Catmambo
No unfortunately not individual apps, just the whole system. I guess you could block their domains on your router if you really wanted to, but thats more complicated and would prevent you from accessing sites via the PC as well..
6 REPLIES 6
CarolMolyneaux
Hi, did you ever get a solution to this problem? I also need to block youtube doue to young kids in house
CarolMolyneaux
for info I've a Bravia KDL-40NX703
profile.country.da_DK.title
Nielsen
I guess an old fashion disconnect if wireless/ remove wire if wired is the only way, depending on your kids ingenuity. Maybe your router has some blocking options also.
Catmambo
You can also I think set up a Pin number to prevent all access to the TV.
Nielsen
As I understand it pin no. 9999 always work and kids today...
And you will never know unless you notice some funny smiles.
Is it possible to disable individual app's using this child lock ?
Catmambo
