Youtube settings - resolution, fast forward etc...
profile.country.SE.title
Midaz45645735684684567465
Hello support and community.
I have recently bought a KDL-65W855 TV in Sweden for like 3000$+
I would like to know how I can change the current resolution and fast forward etc.. on this TV in Youtube?.
It seems I can LIKE and DISLIKE clips but seriously Im I missing something here..
Thanks for any tip(s) :slight_smile:
-Peter
7 REPLIES 7
Shorey66
I don't think you can change the resolution, it just plays at the highest it can with the connection you have.
Thanks Shorey66 for the attention.
What channel do we use to escalate requests to the proper department?
I feel it is important to be able to change resolution/bandwidth and resolution
for any given streaming site or app.
-Peter
Hi there
For internal Youtube application functions/issues/developments, you will need to contact Google/YouTube : see their online forums : HERE
Thanks Quinnicus, but honestly I dont get it
Youtube probably has a standardized interface which streaming clients connect to.
Why would Youtube change anything on their interface when it works wonders on other platforms.
It must be Sony that has neglected to utilize these controls properly in their application.
Sony must fix these things in their end, not Youtube by posting on their forum.
-Peter
profile.country.da_DK.title
Nielsen
My youtube app has SD/HD resolution setting choice under options menu, -but that's it.
There is 3 steps of fast forwarding/ rewinding speeds using the arrow keys repeatedly, which is quite fulfilling imo.
Strange, what model du you have Nielsen?
Pressing options for me yields general picture/sound/3D settings
that are not youtube specific.
Nielsen
I have a KDL-37EX720. The options menu, when a youtube video is playing, has several youtube specific selections and zoom in & out + some generic. However if the selected video is only available in SD the resolution selection is not there, which ofc makes perfect sense.
