Bravia 40RE453 Question
Iguassu55
I am planning to buy a 40" Bravia 40RE453 but the specification only shows 4.6cm beneath the TV when it is standing on a unit.  Is it possible to fit a soundbar under this TV? I cannot find one slim enough, most seem to be around 6 - 7cm in height. Is the stand adjustable to give a bit more space?  If not this seems to be a poor design by Sony.
Iguassu55
Owen_G
Hi Iguassu55. Thanks for your message. We are looking into this and someone will get back to you shortly. ^Owen
cass_n
Community Team
Hi @Iguassu55,
I have checked this for you and confirm that you cannot adjust the height of the TV stand.  You can remove it and mount the TV to a wall, but there is no way to adjust the height I'm afraid.
Cheers,
C
