Bravia tv cant open movie files
madavis11
I have my bravia tv connected to my router and can access all my photo's wirelessly,from my  PC  however all movies stored on my PC are recognised and found, but some reason will not open and play.
can anyone help me
Is it that the movies are in a wrong file format ?
specialist-convergence
Hi
could you advise what media server is being used, most PC Media servers will transcode your files to a DNLA generic format, this has to be MPEG for SD video or M2TS for HD, there are not many packages that will stream the native format
Ballcocks
Try using PS3 media server on your PC. Worked for me, had to edit one of the config files.
sony-frustrated
What config file did you change.   PS3 media server will not find the Bravia TV
