EDF-E50A12U LAMP
scrubdoc
EDF-E50A12U LAMP
how does one change the lamp on EDF-E50A12U
-frank-
Hi scrubdoc,
welcome to the forum :slight_smile:
I'm not familiar with all model numbers myself, but after a quick search, I wonder if you meant KDF-E50A12U, as I can't find any reference to EDFetc.? If it is, it might be a good idea to edit your post. I'm sure someone in the community will know the answer to your question.
Let me know if you want help to edit.
Cheers!
