Bravia TV keeps turning on at random
jentone1
I have been using my TV in our main room for 2 years with no issues. Last weekend I transferred my recorder and catch up digi- box to the main room as my wife finds the menu easier. The TV in the back room has a dedicated on/off switch whereas the new one in the front room is turned off by remote control into standby mode. The recording box also does not have a dedicated turn off button and it too sleeps when switched off on the remote . SInce changing the boxes the TV auto switches on at random and the only way I have been able to stop it is to unplug the recording box. The feed into the TV is an HDMI feed and I was wondering if this is sending a pulse to the TV sensing the box is there and on standby and this is what is turning on the TV.
Does anyone know if there is a fix or will I need to turn off the box every night which will prevent me from recording
Hi there,
Have you tried a factory reset?
Best wishes,
M
jentone1
Yes tried this. I can fix it by disconnection the HDMI lead so its related to the box whilst in standby sending some signal to the TV which switches it on
