calibration
tenpin10
calibration
anybody know good calibration setting for 55x9005b tv
Hi there
In most cases picture calibration settings is an individual personal taste.  It also varies according to your room design and lighting.  Therefore no 1 option is suitable for everyone.
My advice is the following
  • Factory Reset the TV and..
  • Turn off all processing options and...
  • Write down all settings either on paper or a spreadsheet and...
  • Slowly change the settings over a period of time, remembering to write down on your spreadsheet each setting you have changed (for reference later on)
From my understanding thought, the X9005B settings are rather good Out Of The Box (once disabling add-on processing)
You could also use a set of calibration videos (available free) from : HERE
Alternatively you could purchase a professional calibration disc, such as
  • Disney WOW (US Import) : HERE
  • Spears and Munsil : HERE
Or even get a professional to do it for you.  Some good advice is : HERE
Hope this helps.
Hi there
Hope this helps.
