can't play (mkv) files larger than 4GB on bravia 2011 tv
profile.country.no_NO.title
harddisk33
after running mkv files thru mkv2vob v2.4.9 on following settings i GET playback on files smaller than 4GB.
files larger than 4 gb i have to split up by using the fat32 file splitting setting in the mkv2vob to play
proffered audio: eng (irrelevant)
file splitting: none (or i get the cant play message)
video transcoding: never
output file extension: m2ts
output type: AVCHD - usb
proffered sub: none (irrelevant)
transcoding codec: x264 (irrelevant)
following boxes are checked: alw trans DTS, use 448kbps and auto upd
the usbstick i use is 16gb large and is formatted in exFAT with cluster size 128kb.
i know that fat32 file system has a limit on files at 4gb but like i said i use exFAT so that's not the problem.
so i thing that Sony has made a restriction on playing files larger than 4GB, the question is why would they implement exFAT if they are restricting playback on larger files?
tvmodel: 55EX725
if sony bravia team reads this pleas answer :slight_smile:
13 REPLIES 13
profile.country.sk_SK.title
make.believe3
I am having the same problem. I am disappointed quality, funcionality. If sony bravia team reads this pleas answer.
Message was edited by: make.believe3
tripodzid
I also have the same problem. MKV files are for HD movies. I didn't thought that Bravia won't be able to play all movies that exceed 4GB. Is there any other way to play a very HD movies in Bravia?
_______________
Business is the game!!
make.believe3
The (Samsung) tv does not have this problem. Play the MKV file has :thinking:
pamindic
Absolutely correct. Bravia - no support for subtiltes, no support for MKV, no support for high-res jpegs. You have to ask yourself what this telly is for - it's woefully deficient as the centre of a media system.
Sony TVs cost a lot of money, and I think Sony customers deserve better functionality than this company is willing to provide. Sony seems to be trading on its name, but that won't last for ever. My girlfriend needs a new TV, and I'm advising Samsung or LG, where they take customer needs seriously. I recommend to others that they do the same.
