Connect LG3530 Sound Bar to Bravia 40S310
ropaley
My Sony Bravia model 40S310 does not have an optical outlet and the LG3530 Soundbar only has an optical input connection. What kind of adaptor do I need to connect the RCA outlets on the TV to the optical input of the soundbar? After I make these connections, What adjustments do I need to make to my TV to listen to the sound from the speakers? Thanks in advance for your help for a soundbar Newbie!
Hi there
A quick look on Amazon brings up the following : Here
Please read the description and reviews to ensure that it really is the product that you require (I believe it is)
