Copying onto USB stick
BuntyToo
Hi.  Is it possible to copy pictures from my p.c. onto a usb stick and then view these via my Sony KDL-26S55 television?
Yes you can but the following conditions are necessary:  -
1.  The USB stick must be formatted as FAT32 or FAT16
2.  Pictures must have .jpg file extention
3.  Pictures edited on a computer usually don't work.  If they have just been downloaded from the camera without being edited then they should be OK.
4.  Music must be in .mp3 format.
Have a look at Page 21 of your User Guide for viewing instructions - you can download a copy here: -
http://pdf.crse.com/manuals/4127735141.pdf
:wink:
:wink:
