digital & analogue channels interfering
etritd
I  have plugged into my Kdl-32cx520 antenna socket both the digital cable from my service provider & the aerial antenna cable using a simple adapter (attached pic.). it does seem that digital cable channels interfere with the analogue aerial ones and the analogue channels 25 & 27 do not work. once i unplug the digital cable, the analogue ones start work ok. is there a way I can use use both services without  interfering each other? (maybe some more sophisticated adapter to plug both cables)
Bravia55HX
im afraid you gone about this all wrong, remove that adaptor it will serve no perpose here, the freeview aerial should be plugged into your tv and your service provider (without knowing which one) should be connected via HDMI, you cannot feed freeview and service provider through the same socket thats why your experiencing problems.
etritd
just wanted to avoid the hd box of my service provider by using CAM and that is workin fine beside the above issue. anyway, thank u. really appreciate ur answer.
