Direct-CM-Bravia
christy_900
Direct-CM-Bravia
I set up my HDX853 yesterday and when going to internet settings a code came up which asked me to put in my computer.  My brain went blank and couldn't think what this meant and I didn't write it down.  I now have a new network listed on my computer called Direct-CM-Bravia and now realise the code was to allow access to it.  My problem is I now don't know where to find this code in the TV settings
Catmambo
Hi - What are you trying to do? Could always just go through the network setup process again, or worst case run a factory reset if you want to start from scratch?
Catmambo
