Error message on BBC i player
muffin1947
I just tried to watch a program on BBC i Player and keep getting the following message can someone explain what it means.
Internet failed because download content exceeded system memory unit
My tv is a Sony Bravia
4 REPLIES 4
jumpsuit
Hi @muffin1947 :slight_smile:
I think something must be broken again their end 😞
Have a look at this thread:
https://community.sony.co.uk/t5/other-tvs/kdl-47w805a-tv-message-of-system-memory-limit/td-p/2263247
cheers
Hi @muffin1947
Do you still have the TV model:  KDL-42W653A  and is this error is on this particular TV.
If so, this particular error was reported fixed by the BBC in December last year.  I have been hearing reports that this might have re-occured, but no one is replying back to confirm their model number of the TV.  Without a model number I cannot report this up the chain via Sony to the BBC.
At current it is confirmed as:
  • 2011 Models - BBC is terminating iPlayer, but previously had this error message
  • 2012 Models - No error messages on iPlayer
  • 2013 Models - Unconfirmed reportings - I suspect though
  • 2014 Models - Has this error message.
muffin1947
Yes I still have the   KDL-42W653A  and this is where the problem occurs.
mttwyew
internet download failed because content exceeded system memory limit
I have this error on a Sony KDL-32W705C- I also have a problem on the same TV in that I can load Netflix but when I select a program/film to watch it loads very slowly and then drops back to the TV channel
