Format usbpen: lost 7GBytes
profile.country.it_IT.title
mcanonic
I've bought a new 32GB pen drive and I had to format it, in order to make recording feature working.
After the format process, I've realized that 7Gbyte are no more available.
How is it possible?
Cheers,
Massimo
Bravia55HX
no storage medium anywhere will be anywhere near the capacities stated, i bought a replacement drive for a laptop that was 320gb and when installed was in fact 298gb and this is perfectly normal, i cant explain it in simple terms and many of us wont understand it either but heres an extract from another forum why this is.
The reason why you don't get the full 320GB is down to way the formatting of the drive from Bytes to...
confused yet? so am i, forget about it or buy a bigger drive!
