Green lines on TV
ibbiole
Green lines on TV
Hi. I have a Sony kd65S9005. I have developed multiple green lines on the screen which don't seem to go away. I have tried everything and I mean everything.
Is my product under the 5 year warranty?
jumpsuit
Hi @ibbiole
It depends where you bought it from and what the warranty terms were at time of purchase.
If it was from Sony you can contact support on +44 (0) 2073652810
and they will  be able to help you.
(Which you will have to do anyway judging by your TV fault.)
