Scenes greyed out on kdl-40rd450
profile.country.RO.title
Korodilu
Hello all. I have a kdl-40rd450. I try to change de scenes from scene select and not all are available. Only general,cinema,sports and music are available. The others are not available .do you have any idea?has anyone of you had this kind of issue?
Thank you
Mick_D
Moderator
Hi Korodilu
We should be able to find a solution to this for you; please bear with us while we check it out.
Best wishes
Mick
Owen_G
Hi again Korodilu,
The lack of available options could be due to the inputs you're using, or not using. It may also be that these other options are for consoles etc., rather than for watching your television.
Thanks,
Owen
